585,763 active members*
4,154 visitors online*
    Jun 2014
    1780
    PP edit window
    Anyone know why I am minus the edit window (2.8.1)? I wonder if it could be the computer? We do use HF on the welder at times. I rebooted and re-downloaded and installed the update again to no avail. PP runs OK though, I just cant edit the post processor files.
    My other computer that I test PP on has the window with the same update (2.8.1) and it works fine.
    The reason I noticed it was that I was trying to edit a tapping macro to remove the G4 P2. delay, this is the one when it finishes tapping a hole it returns to Z clearance height then waits 2 seconds before moving to the next hole.
    mike sr
    Aug 2016
    132
    Re: PP edit window
    Click on the right side of the screen (there is a small pane of dots that is very hard to see), hold the mouse button down and drag the preview pane to the left to make it visible
    Jun 2014
    1780
    Re: PP edit window
    Quote Originally Posted by footpetaljones View Post
    Thank you sir!
    I had no idea those windows would change size, much less how to do it!
    mike sr
    Jul 2017
    70
    Re: PP edit window
    The vertical resizers also toggle snap to common positions if you click them.
    Jun 2014
    1780
    Re: PP edit window
    Quote Originally Posted by old-cnc-geek View Post
    That is good to know as well, thanks.
    mike sr
  1. Okuma post edit or CAM edit?
    By dfearnow in forum Okuma
    Last Post: 12-30-2015, 11:47 PM
  2. :ayers Window
    By Noah46 in forum BobCad-Cam
    Last Post: 02-18-2015, 11:23 PM
  3. Window for the webcam ?
    By lelelodi in forum Screen Layouts, Post Processors & Misc
    Last Post: 09-25-2012, 12:31 PM
  4. Output Window
    By programmer4fcmt in forum Esprit
    Last Post: 11-02-2011, 10:58 AM
  5. Missing Window
    By Andre' B in forum NCPlot G-Code editor / backplotter
    Last Post: 09-18-2008, 12:59 PM
