585,902 active members*
4,966 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > Granite horizontal 5 axis build inspired by Grob/Kern
Results 1 to 2 of 2
    Jun 2013
    4
    Hello all!
    I have been spending way too much time rabbit holing on a new machine build and I wanted to share my progress and get some design feedback.
    Inspired by @Fox3d and Dan Gelbart designs, I have been accumulating granite surface plates for a while, including one huge 4'x6'x10" beast ($100!!!) which I have made the base of this design. I want to get into 5 axis work and am very interested in the Grob and Kern machines. The design goals for the build are having a highly accurate machine that can have a decent 5 axis workspace I can use for R+D and small runs(I work in the robotics industry designing and building autonomous robots). Mainly this is a learning project.
    Experience-wise in this realm, 10 years or so ago I retrofitted a Maho with Linux CNC, so this is not entirely my first rodeo, but it is my first new build of a CNC machine with modern drive systems.
    I have been accumulating ballscrews, servo motors, robot parts off of ebay etc for a long while, so I have much of the drive and structure components already in hand.
    The plan for the axes carriages are building them with 2"(or 50mm) Aluminum Cast Tool and Jig plate (eg Mic6 etc) as they come already precision ground, and then sanding them on the surface plates (like fox) to final shape. Anyone have a sense for how parallel and flat they are from the factory? I have only used material like this for making molds in the past.
    The Kern machines use aluminum for their precision axes because it is good at dissipating heat quickly, and very predictable under thermal change, so there are no temperature gradients in the material. You keep the plates at a constant temp by running chilled fluid through them, and the kerns cycle a huge amount of the ethylene glycol per hour to do this. I bought an old SMC chiller, but not quite as big as what they are doing.
    The spindle is a Fanuc new old stock spare from an old Hitachi Seiki HG500, which is huge. It powers a direct drive hsk63 cartridge.
    The axis motors are Fanuc pulls from robots. m9 motors with 65k / rev absolute encoders and brakes.
    Servo drives are Kollmorgen ethercat units.
    The 5th axis table will have two of the large harmonic gears from an old Kuka robot I have (kr350), and may be an adventure in aluminum casting... We shall see!
    Here is the current state of affairs. It is still plenty rough of course.
    Attachment 468900Attachment 468902Attachment 468904Attachment 468906Attachment 468908
    Please give me any design feedback you have! I need to get this into FEA asap and take a look at how those plates are going to take deflection like @petereng is doing on his awesome milli project.
    Jul 2018
    6333
    Re: Granite horizontal 5 axis build inspired by Grob/Kern
    Hi Asah - The trunnion face will need to be thicker similiar to the base... the steel frame will not match the stiffness of the granite slabs. The machine will only be as stiff as its most compliant part. I'll be watching! Peter
  1. My Granite Vertical Mill Build
    By MattyJ4 in forum Vertical Mill, Lathe Project Log
    Last Post: 08-24-2017, 08:45 AM
  2. Momus Inspired Build Log
    By qbvbsite in forum CNC Wood Router Project Log
    Last Post: 04-05-2017, 08:13 PM
  3. $1000 Microcarve 3 inspired Build in 2 weeks
    By taiden in forum DIY CNC Router Table Machines
    Last Post: 01-21-2014, 04:00 AM
  4. 4Th axis add on build using epoxy granite and R8 spindle
    By Sil_x in forum Open Source CNC Machine Designs
    Last Post: 10-01-2011, 06:36 PM
  5. Anyone want to build a Polymer Granite machine with me?!
    By blurrycustoms in forum Uncategorised MetalWorking Machines
    Last Post: 08-17-2009, 02:43 AM
