585,914 active members*
3,783 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Flipped part and chamfers are offset on x axis
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    15362
    Re: Flipped part and chamfers are offset on x axis
    Quote Originally Posted by dazp1976 View Post
    Depending on the hole size, I kept a load of broken end mills of varying sizes.
    I use the shanks of these fitted into the spindle nose to line up to a drilled hole. Generally between sizes 3-8mm.
    Broken End Mills, where do they come from, I have hundreds of End Mills but no broken ones.
    Yes this is a way to do it if you have +/- .005" on a part tolerance.
    Gauge Pins or bar stock work for this rough hole location method as well.
    Mactec54
  2. #22
    Aug 2009
    1573
    ...use a nevusor nully Dial Indiccator...when Jig boring holes
    https://www.ebay.com/sch/i.html?_fro...apid&_osacat=0
  3. #23
    Jan 2018
    1516
    + remember that, if you enter side 1 from say bottom left and flip it over left to right. Enter side 2 from bottom right, ergo opposite side. This helps against a machine that has some backlash.
  4. #24
    15362
    Backlash is still there no matter how you look at the part, if indicating a Hole, you will see any backlash if there is any, with using a pin you won't know what or where you are with the machine backlash.
    Mactec54
Page 2 of 2 12
  1. Part work offset
    By astral in forum Okuma
    Last Post: 03-13-2021, 10:16 PM
  2. Fillet and chamfers - 3 axis milling - CW4SW
    By itolond in forum CamWorks
    Last Post: 06-27-2018, 11:41 AM
  3. Replies: 2
    Last Post: 02-17-2013, 06:37 PM
  4. FLA-100. Flipped part wont line up! Software or mechanical?
    By Zeppelin1007 in forum DIY CNC Router Table Machines
    Last Post: 11-15-2012, 01:54 PM
  5. 5 axis chamfers and dovetails
    By gwb in forum Mastercam
    Last Post: 02-03-2012, 09:29 AM
