585,760 active members*
3,975 visitors online*
    Aug 2021
    Milltronics Partner ID
    Hello, I recently acquired an old Milltronics Partner mill from an estate sale. The last owner isn't available to get information from. He removed the Centurion controls and installed his own cabinet with a HiCON Intregra 7766 motion control board and Mach 3. He also removed the machine serial number plate so I have no idea which model machine I have. The machine came with some manuals which I posted a link to in the manuals forum. They are for a Partner 6F or 7F machine, but don't look like the same machine. I contacted Milltronics support and they tried to help, but they said they lost a lot of older documentation in a data hack. They thought it was a Partner 4 series machine. Does anyone here have an idea which model this is? I have attached a few pictures.
    Sep 2010
    529
    Re: Milltronics Partner ID
    It is a Partner 4, you have a manually adjusted variable speed head and I don't see the pancake air cylinder on top for the tool changing. The rest of the machine looks the same as mine. I have a mechanical manual in my Dropbox, it should help you out.
    https://www.dropbox.com/s/187adtasei...%204S.pdf?dl=0
    Aug 2021
    Thanks Brian! I'm sure there will be enough missing pieces to keep me busy for months.
  1. Milltronics Partner VI, Partner 6 - $1.00 no reserve
    By donl517 in forum For Sale Only
    Last Post: 03-17-2018, 02:40 PM
  2. Milltronics Partner 1G
    By BilletCharlie in forum Milltronics
    Last Post: 07-11-2013, 04:21 AM
  3. FS: Milltronics Partner I
    By SpeedMetal in forum Milltronics
    Last Post: 11-23-2010, 03:28 PM
  4. Milltronics Partner
    By MSGMachine in forum Viper Servo drives
    Last Post: 06-03-2009, 02:22 AM
  5. Milltronics Partner IV
    By Ben Colby in forum Milltronics
    Last Post: 03-27-2006, 11:53 PM
