plane problem mc 2020 for solidworks
Experienced SW user, total new user of MC though. Trying to do the CAM for a flat rectangular part with a bunch of holes. Axes were all screwed up because the original sketch was drawn on the front plane. I moved it to the top plane in SW. The large gnomon in the MC window is correct now. When putting in a drilling op, the large green arrows come up as pointing up from the bottom though; I flip them all in the drill dialog box. if I right click on the drilling op in the feature window the simulation works fine, but if I go to the machine simulation button in the ribbon and try to run a simulation there I get "the toolpath is not correctly oriented. the current machine definition can't post this toolpath. do you want to rotate the toolpath" to which I answer yes, then I get the toolpath is not for 3 axis machine, posting process exception. I think I need to flip the part; does this mean I will need to delete and redo the drilling ops? or Can I flip the gnomon so the z is down and then regen? Also my large gnomon axes do not align with the small gnomon axes in the lower left corner, if that matters...not sure how to proceed when one sim works and the other doesn't. I have not yet tried to post...
See my stuff for sale at http://stores.ebay.com/Industrial-Tool-and-Machine-Works?refid=store
