586,011 active members*
4,057 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Yaskawa 100V or 200V single phase servos
Results 1 to 9 of 9
    Aug 2021
    4
    Hello, I am new to Yaskawa servos and need help.
    I have a 120V single phase to power a Yaskawa servos (less than 500W) which are rated either 100V single phase or 200V single phase. How do I power say a 100V servo with a 120VAC - would you suggest I use a step down transformer? Thanks.
    https://www.yaskawa.com/products/mot...sgd7s-ethercat
    Re: Yaskawa 100V or 200V single phase servos
    You only linked the family of servo drives and didn't provide a specific model, however the 100V servos are listed in the technical docs as 100VAC to 120VAC -15% to +10% for voltage range on the 100V single-phase drives. Just wire it up, unless you have something that is putting abnormal spikes on your line.
    Do make sure it's listed as an appropriate pair with the servos you have. If you purchased it from a Yaskawa vendor then that shouldn't need to be checked.
    The 100V single phase only pairs with up to 400W servos, fyi.
    Attached Thumbnails Attached Thumbnails Yaskawa_Pairings.png   Yaskawa_ModelNum.png   Yaskawa_100VRatings.png
    Dec 2013
    5717
    See: https://www.yaskawa.com/products/mot...ec_CoreManuals
    Sigma-7S SERVOPACK with 100/200V Input power and EtherCAT (CoE) Communication Reference Product Manual
    Page 2.4
    Jim Dawson
    Sandy, Oregon, USA
    15362
    Quote Originally Posted by Nor1 View Post
    You can use / connect the 120v to the 100v Ac servo Drive without any problems is the servo Drive single Phase what is the model number of the Servo Drive
    Mactec54
    Aug 2021
    4
    Yaskawa Servos and Motors are:
    • SGD7S-R90FA0A
    • SGD7S-2R8FA0A
    • SGM7A-01A7D6C
    • SGM7A-04A7D6C
    Aug 2021
    4
    Quote Originally Posted by StrawberryBoi View Post
    yes, 100W and 400W. Where does it say -15% to +10% for voltage range on the 100V single-phase drive in the spec? I could not find it.
    The nominal voltage can vary up to 5 percent. This puts the acceptable voltage range of a nominal 120-volt at between 114 and 126 volts. For Yaskawa, -15% to 10% is 85VAC to 110VAC which is outside of the fluctuation of the nominal 120V?
    15362
    They have been used for the last 40 years on 120v Ac for the 100v drives 240v Ac for the 200v drives I have never seen a failure because of the input voltage
    One thing never to do is to use a Plug to disconnect / or connect the power
    Mactec54
    15362
    • SGD7S-R90FA0A
    • SGD7S-2R8FA0A
    • SGM7A-01A7D6C
    • SGM7A-04A7D6C
    These will be expensive why these new models you can get the same from older models at a lower cost
    Need to know more of what you want to use them for
    Mactec54
    Aug 2021
    4
    I guess I was blind, just noticed it
    Single-Phase, 100 VAC
    "Main Circuit Power Supply 100 VAC to 120 VAC, -15% to +10%, 50 Hz/60 Hz"
