585,954 active members*
4,237 visitors online*
Results 1 to 12 of 12
    Oct 2010
    26
    EDM machine - working table doesnt move
    Hello,
    I have a wire cutting machine (FANUC TAPE CUT MODEL I, MATRA: 945 Series: 6m system).
    The machine was purchased a long time ago in Germany, with no technical documentation supported.
    The machine was working great for many years without experiencing any big issues. Now, I have a problem that I am not able to fix.
    Here is the scenario:
    - When the machine is in auto mode, the working table doesn’t move.
    - When I say auto mode, I set a switch from JOG to MEMORY mode, enable all conditions (wire, tension, power, water), and press the START connector. After pressing START connectors on the screen the working desk is not moving and the positions of the X and Y axis are not moving as well.
    - Also, I am not able to send the machine in a reference point in auto mode, in manual yes.
    When I run the machine in the Manual mode, “set switch to JOG” – I am able to move the working desk. X and Y coordinates are working.
    Any information would be very useful.
    Sep 2015
    11
    Re: EDM machine - working table doesnt move
    I have similar machine (W2). I had similar problem.
    Possible solution:
    The machine have addition safty switches: workspace cover and cover of cabin of waste wire .
    I can take pictures if you don't find.
    Oct 2010
    26
    Thank you for your reply. I am looking at it but the only switch I see is for changing parameters.
    Do you mind to take a picture please, it may solve my problem too.
    Thanks in advance,
    Dzenad
    Sep 2015
    11
    Hi Dzenad!
    I don't know your type exactly (Type: L ???), but I think this failure or situation is same as. Missing enable signal from something status switch. Plexi cover!!!!
    As I mentioned: my W2 has waste bin of used wire with cover with switched monitoring. I hate the cover, therefor I hacked the sensor-switch. I glued it down. I attaching a pictures with red circle where are switches. I am not near the mahine, I haven't got better photo.
    So, I have another machine, it is Fanuc T3 without cover and door but it is running. You can change the parameter of machine according to deactivate switch monitoring.
    Tomorrow I study for it.
    Best regards, Elek.
    Oct 2010
    26
    Hi Elek,
    Thank you for the image. Unfortunately, I am not able to find the switch. I don't have machine documentation as well and not able to find what parameter to change.
    Please check the link where I uploaded few images. https://drive.google.com/drive/folde...ZC?usp=sharing
    On the machine, there is a stamp Fanuc Matra Tape Cut model I. I guess It is the first model of this kind. After you see images, maybe you can navigate me. I think we have the same problems.
    If the machine is moving in Manual mode, by pressing X and Y connectors I think electrical motors are in function. What is your opinion?
    Regards,
    Sep 2015
    11
    Hi Dzenad,
    sorry for late answer.
    Yes I think, too. The cutting process wait for something enable signal. I showed by red circle in your picture: these are the buttons (cover switch). You have to sure it is short-close and all other (if you find). Unfortunately, you need disassembly (unscrew the plates). I look the machine is without cover, therefore I think somebody make the short circuit earlier. Maybe it is released (open).
    Sorry, I didn't study the parameters, yet.
    Elek
    Sep 2015
    11
    Hi Dzenad,
    I compared the parameters of my machines. I have machine book to all together (Fanuc W2 and T3). I dont know, what mean are the below parameters (in the machine book not mention), but these are different. Please, try the change step by step.
    P0023: 10000000
    P0024: 01000010
    I wait for feedback.
    Good luck!
    Oct 2010
    26
    Hi Elek, thanks a lot for the instructions.
    Unfortunately, we are not able to solve the issue. I was checking those parameters as well but no luck
    It is very unusual, as the machine table is moving in manual mode. When in automatic mode, it stops without any warning or error being displayed.
    Is there anything else you have in mind I can try?
    Sep 2015
    11
    Hi Dzenad,
    if you are in the "auto-mode": can you run program and moving by "dry-run"?
    Elek
    Oct 2010
    26
    Hi Elek,
    When the machine is in Auto mode, I cannot run the program with DRY RUN. When I enter that process, after clicking START, the machine just doesn't move the table.
    In Manual mode, when the switch is in JOG mode I can move the table manually by pressing the X and Y axis.
    Sep 2015
    11
    Hi Dzenad,
    this is bad news.
    I have no idea now, I am consulting with colleagues (Fanuc fans) in Hungary (whom I know).
    Rtegards, Elek.
    Sep 2015
    11
    I tested my W2 machine: it is with switch (cover) controlled. Mean is: if I want to start cutting without cover the machine dosen't move. At the paralell I want to start by dry-run (and without cover), then the machine moving. It is a big different on your situation!
    Unfortunately I haven't got any idea for issue.
    If you want I can scann my parameter from book but it is different for your machine....
  1. cnc plasma control XPTHC-4 torch doesnt move
    By shakibdriss in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 05-23-2017, 07:42 PM
  2. Upgraded to Corel X8 ,yet machine SW doesnt support it
    By TSHobbies in forum Laser Control Software
    Last Post: 10-13-2016, 03:07 PM
  3. Machine doesnt pause for spindle to stop
    By Lomach in forum LinuxCNC (formerly EMC2)
    Last Post: 07-30-2012, 09:34 PM
