585,969 active members*
4,644 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Exception [24,5] - NCI(8,3): Communication with the CNC does not work! Morbidelli
Results 1 to 6 of 6
    Aug 2021
    Greetings
    I need help with this error that I encountered on a Morbidelli Autor 600 kXLS CNC machine after changing the battery of the numerical controller. I have contacted SCM but they have not given me a solution.
    The error is as follows
    Sep 2021
    Re: Exception [24,5] - NCI(8,3): Communication with the CNC does not work! Morbidelli
    Did you shutdown the whole system all the way to the main switch after youv'e changed the batterie ? And does your main was at off when youv'e changed the batterie ? Changing the batterie while the main is off might cause data loss. I work on scm morbidelli N200 & Morbidelli universal 3615, and when the exception 24,5 occur shutting down 3/4 of time solve that problem.
    Hi Greg
    I have the same issue did you find a solution?
    Jason
    Jan 2015
    35
    Quote Originally Posted by jasonmc1967 View Post
    Hi Greg
    Jason
    What led light is on num plc?
    Quote Originally Posted by dmitry83 View Post
    Green
    Dec 2019
    Had this issue and I believe i had to change the baud rate
  1. Morbidelli Author 500 communication problem.
    By mobsta in forum CNC Machining Centers
    Last Post: 06-28-2022, 02:06 PM
  2. Xilog plus Communication failure with cnc except [24.5] NCI (8-1019)
    By Alexandrosm200 in forum CNC Machining Centers
    Last Post: 12-21-2019, 03:48 PM
  3. Gibbscam - outputting nci or nci equivalent
    By soymilk in forum GibbsCAM
    Last Post: 11-06-2018, 03:10 PM
  4. Screen editor --- Unhandled exception
    By todmorg in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-01-2018, 05:14 PM
  5. Turning simulation throws exception
    By keith20mm in forum Dolphin CAD/CAM
    Last Post: 10-24-2016, 03:39 AM
