585,962 active members*
4,141 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Indian carving technique
    May 2017
    23
    Hi everybody.
    I have a 1200x900 chinese cnc router that works pretty well.
    I intend to make doors and furniture like those on the attached pictures.
    I have the good bits and the right technique. But when I start engraving the gantry and the spindle shake and the line created on the material is distorted. I think that the spindle and the gantry are not strong enough to work on hardwood. What do you think about that ? Can you advise me ?
    Is it a problem of feedrate and spindle speed ???!!!!!? I'm lost.
    Some samples of my works are attached.
    HEEEELP !!
    Apr 2004
    5737
    Re: Indian carving technique
    I doubt that your problems are due to feedrates or spindle speeds. Most likely, your machine just doesn't have the rigidity required to make a good cut in hardwood. When it works "pretty well", what are you cutting?
    Andrew Werby
    Website
    May 2017
    23
    Quote Originally Posted by awerby View Post
    Thanks for your prompt answer. I agree with you that rigidity IS the issue. Anyway I'll try that technique with tender then see if I Can deal with it.
    Mar 2009
    1982
    what is static run-out of your spindle?
  1. BLUE ELEPHANT Indian customer visit feedback
    By elephantcnc in forum Videos
    Last Post: 11-07-2018, 04:36 AM
  2. Indian Motorcycle Logo
    By rockjunky007 in forum MetalWork Discussion
    Last Post: 11-22-2016, 06:54 AM
  3. job vacancy for an indian designer
    By cuteplanet in forum ArtCam Pro
    Last Post: 05-15-2015, 01:19 PM
  4. Hi from Mayotte (indian ocean)
    By JFP976 in forum European Club House
    Last Post: 07-17-2008, 10:23 PM
  5. Relief carving small detailed parts - V-carving from greyscale image
    By ALAN2525 in forum Uncategorised CAM Discussion
    Last Post: 02-12-2007, 12:01 AM
