586,024 active members*
4,391 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > what is the easiest way to tell mach that the vfd/spindle is running or not?
    Apr 2004
    79
    I am planning on just manually turning the the spindle on and off but I am concerned with how finicky the vfd can be sometimes. What is the easiest way to tell mach that the spindle is running or not? The only thing I am concerned about is the spindle faulting out for some reason and the machine just keeps going because it does not know the spindle has stopped. I am using a hitachi wj200vfd with the ebay special 2.2kw
    I'm not really interested in controlling the spindle with mach I do not really need that I just want to be safe and not end up with a machine crash scenario because of a faulted spindle.
    Dec 2013
    5717
    Re: what is the easiest way to tell mach that the vfd/spindle is running or not?
    That drive has a relay that can be programmed for many purposes, one of those being Drive Fault. Just wire the relay into your E-stop circuit and if the drive faults it will trip the E-stop.
    Jim Dawson
    Sandy, Oregon, USA
    24221
    Another couple of outputs that I used was at-zero-speed to indicate if the spindle was running, e.g. start the coolant pump etc.
    The other was up-to-speed in order for the Sxxx block to carry on to the next instruction.
    Albert E.
  1. Replies: 18
    Last Post: 02-09-2019, 07:31 PM
  2. 5.5Kw VFD running a 2.2Kw spindle
    By stefancnc in forum Spindles / VFD
    Last Post: 05-15-2018, 02:31 AM
  3. Hitiachi VFD NE-S1 - Spindle running at low rpm
    By gritandgrainco in forum Spindles / VFD
    Last Post: 02-01-2018, 04:09 PM
  4. Hitiachi VFD NE-S1 - Spindle running at very low rpm
    By gritandgrainco in forum Phase Converters
    Last Post: 01-29-2018, 08:43 PM
  5. Replies: 13
    Last Post: 05-15-2015, 10:03 PM
