547,211 active members*
3,068 visitors online*
Page 3 of 3 123
Results 41 to 44 of 44
  1. #41
    Re: Help a Newb Build an 8x4 Machine ????
    Thanks fellas, I understand I need to know what’s forces I’m wanting to achieve, at this stage, I just wanted to get a rough idea of the cost of the Linear Motors system, to see whether it’s worth putting the time into planning any further. The amount of hours Iv spent searching for things, I could have designed a rotating ball nut bearing carrier..lol
    Still, I do very much like the look of these Linear Motor tracks, with your suggestions in mind I will get some prices for the LMC. Iv looked through all the specs of the LMC series, there is 5 different models that achieve the same constant and peak N, but the peak Amps differs massively, so I’ve requested quotes for all those that have similar N specs to that LMC-EFE6.
    Also asked for quotes on 25mm guide rails.
    HG series(Heavy Load and SuperHeavy)(Precision grade C and P)(With and Without Dust Seals)
    RG series with a few variables
    QH series with a few variables.
    Will post back when I hear back.
    Regarding what I’m using the machine for.. the possibilities are endless.. immediately I will be machining timber, Oak Joinery and Green Oak Structures, Furniture, MDF, Ply, etc.. I also have some lumps of timber that are hard as hell, probably not far off Alu to machine.
    But, i will push the limits of whatever machine I have, I will probably machine Alu, I’d like to be able to make things like a Ball Nut Bearing Carrier...lol
    Working on the assumption I can just slow the feed speed and reduce material removal per pass when I machine harder things.
    I’m also thinking I’ll add a Lathe at one end.. And AutoToolChange.. probably at a later date..
  2. #42
    Registered
    Aug 2014
    199
    Hi LondonBoards,
    I confess I haven't read the whole thread, but if I can make a couple of comments you can pick anything useful out.
    I've had two simple 3 axis flat table type routers. Both were stepper motor rack and pinion drive and were perfectly adequate for general woodwork and sheet aluminium use. Speed was not a problem. My current home router is an AXYZ Z7 ( similar to this one Camtech Z7 Router - YouTube)
    it cost £800 +VAT and to make it easy to use I replaced the standard controller with a UCCNC 300ETH and old HP PC running the excellent ( and very easy to use ) UCCNC software. So all-in about £1500.
    The good features: Simple rack and pinion drive is fast and accurate enough, good dust extraction via the height adjustable cowl, bigger than an 8x4 sheet so room to park the gantry out of the way while mounting a full sized sheet of ply, 4KW air cooled spindle is simple and powerful enough - never overheats. Combined vacuum and bolt down table is versatile. Proper linear rails and carriages.
    Bad points: Helical rack and pinion would be quieter and smoother, no ATC ( big disadvantage that will be rectified if I ever have to change the spindle ).
    This is an entry level machine for a woodshop, but very useful. It's built on a very solid frame, and is flat bed, so that when not in use the gantry is simply parked at one end and the rest used as a work bench. I think that's better that trying to store half the router in mid-air.
  3. #43
    Hi Zorbit,
    Thanks for your thoughts, I started off thinking I could do that kind of build, seen so many people bash R&P I automatically disregarded it as an option, but I do understand it’s the most cost effective and ‘would do’ for pretty much everything I currently plan in machining.
    I also thought I’d be able to use my existing steel table, which I now know is not beef enough, Steel has rocketed in price recently so just building the bed will be £1000 or so.
    Iv also been put off UCCNC and other PC/Laptop based controllers as heard so many people bash them for lagging, again, probably not a problem for most the tasks I ask of it, but if it has a woopsy it could mess up a £500 piece of work.
    Does UCCNC support ATC?
    Also, I’d need to get another PC/Laptop as mine can hardly run Note Pad, let alone a long CNC program.
    I decided on a Masso controller. It’s standalone, about £650.
    Can’t believe how incompetent Hiwin are.. they have sent me half a dozen emails saying they trying to find someone to price up my list of components.. somehow they’re making what should be a very simple task, extremely complicated..
  4. #44
    Member
    Jul 2018
    3392
    Hi LB - UCCNC does not lag and an old laptop will do the job (I'm using a win7 oldy at the moment on one machine). Use a good motion controller, its responsible for feeding & timing the gcode to the machine. I have used (for over 4 years) UCCNC and a UC100 for 3D machining at 25m/min and it did not miss a beat. UCCNC has suitable outputs for ATC. But Masso is good too. Peter
Page 3 of 3 123
  1. 8x4 router build. which stepper motors. .?
    By dangerousdave in forum DIY CNC Router Table Machines
    Last Post: 09-25-2014, 02:07 AM
  2. Newb with First Machine Design Build
    By jrnesmith in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 02:44 AM
  3. Newb Build Questions...
    By integr8d in forum Benchtop Machines
    Last Post: 08-24-2013, 02:18 PM
  4. Newb starting new build
    By big_squirmy in forum DIY CNC Router Table Machines
    Last Post: 10-24-2011, 12:25 AM
  5. NEWB build. I have some questions
    By mr_thehun in forum DIY CNC Router Table Machines
    Last Post: 04-07-2011, 05:03 AM
