585,977 active members*
4,301 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas MiniMill shuts down without alarm
    Aug 2008
    28
    We have an early model Mini Mill(2001). The machine will boot up and run, but in the middle of a cycle will shut down immediately without any alarm. It seems to happen when the machine is running a cycle. If it is on,but idle it doesn't shut down. Incoming voltage is 208. Thanks for any help!
    15362
    Re: Haas MiniMill shuts down without alarm
    Quote Originally Posted by Mike T. View Post
    Has this always run on the 208v supply, or is this a new install
    Mactec54
    I have the same issue right now with a newly purchased (to me) 95' vf0. Narrowed it down today. Seems that the coolant circuit on the io board has an issue. I unglugged the coolant cable from the io board and machine runs without a hitch. Plug it back in and it may run one tool or a couple then unexpectedly shuts off completely. Turn it back on and alarm is 170 phase l1 and l2 lose.
    15362
    Quote Originally Posted by Afkustoms View Post
    You have an input Power problem it is either low Power supply or it is dropping a Phase, are you using utility Power or a phase converter
    Mactec54
  1. Replies: 1
    Last Post: 01-08-2019, 01:43 PM
  2. alarm 966 on new Haas Minimill
    By nelZ in forum Haas Mills
    Last Post: 10-30-2016, 05:24 AM
  3. MiniMill(Haas)
    By smallplanes in forum Haas Mills
    Last Post: 11-16-2011, 07:54 PM
  4. Haas minimill, what should I know...
    By Freddy Bastard in forum Haas Mills
    Last Post: 07-06-2009, 08:23 AM
  5. HAAS machine – controller shuts down
    By Markus_Oh in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-28-2008, 08:06 PM
