586,005 active members*
4,938 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > 2d cad/cam simplification example
    Jun 2015
    4154
    hello a normal cad should allow drawing basic shapes ( 5 of them : points, lines, circles, elipses, beziers ), and formula driven ones ( less used, but still )
    each one of the basic shapes is handled by its own code, and variations will occure, as one will have to create, for example, intersections
    idea behind this thread is reducing variations, from the consideration that points lines circles and elipses, are nothing but restricted beziers:
    ... line = an analytical bezier
    ... ellipse = interpolated spline, within a given accuracy, that has to be corelated with cnc precision
    *voila, basic shapes set just reduced from 5 to 1, and variations for intersections reduced from 15 to 1
    how most machine operations are lines & circles, there can be used labels to identify that a bezier is a line, or a circle arch, in order to generate relevant g-code / kindly
    Mar 2009
    1982
    Re: 2d cad/cam simplification example
    when computing resources were poor the brief expression of drawing element was important: point has only coordinates and nothing else. Segment of straight line has coordinates of two points and nothing else. Circle has coordinates of the center point and radius and nothin else. And so on. Shapes produced consisted simple segments.
    Today we want to have one complex element with desribed behaviour and parametrise it to whatever shape we want.
    Jun 2015
    4154
    hy it may also have sense, like trigonometric or backwards, and also other parameters if it is considered a particular case of an arch, ellipse or whatever
    if i may, this is only for rough representations, in order to speed up processing speed; for smooth analytical ones. that take more time to compute, where segment size is scaled to fit screen pixels grid, a bit more simple math is involved, segments size being no longer equal, or equal at a resolution higher than the screen / kindly
  1. Accurate CAD | CAD/CAM/CAE Services
    By accuratecad in forum Manufacture Company Listing
    Last Post: 01-02-2017, 11:39 PM
  2. Accurate CAD | CAD/CAM/CAE Services
    Last Post: 12-29-2016, 05:18 PM
  3. BobCAD-CAM Releases New v28 CAD-CAM Software Series
    By aldepoalo in forum BobCad-Cam
    Last Post: 07-16-2015, 01:50 AM
  4. Replies: 0
    Last Post: 03-31-2015, 06:55 PM
  5. Seems the CAD/CAM (esp CAM) dept is vacant in Linux - Am I correct?
    By 777funk in forum LinuxCNC (formerly EMC2)
    Last Post: 09-06-2012, 10:05 PM
