You obvious have no electrical knowledge, simple high school math will tell you that a 13A Single Phase supply to the VFD input, will not give you a 3Phase 10A output, which is needed to have the full Power for the 2.2Kw spindle motor, remember simple math.
Low power supply means low performance, as I said these spindles can run on a low amp power supply, but you are not getting a 2.2Kw performance, you can calculate what you are getting out of your spindle, by what your power supply current draw is, your connection of 13A will give you around a 1000Watts at best, that's a long way from 2.2Kw so stop dreaming, that you are running a 2.2Kw spindle on your power supply because you are not.
Here is what your ABB VFD Drive manual says you require, I guess that you know better than the manufacture. if you think any different
A note if you are fitting these VFD Drive and using these connections this would be illegal wiring, so I hope if you are doing this for anyone that they know what you are doing is not to the electrical code requirement's, for an install like this.
