585,778 active members*
4,165 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Floppy emulator for an Okuma OSP7000L
    Hi all I hope you can help me.
    I have an Okuma OSP7000L CNC machine where I am based.
    As i am sure many of you are aware, good old floppies are really out of date.
    As I work in the IT department, I had discussed with the department with the idea of swapping the floppy drive out with an emulator. I have tried two variants with no success.
    The first emulator was a cheapo Gotek unit which only has two segmented displays. Despite various settings this never managed to get far in reading files and would always throw an error (was long ago so I can't remember).
    The second Emulator which I tried today was a Lotharek HxC SD card floppy emulator. This one, I had better success, in that I can get the okuma to read the file but upon attempting to 'copy' the file it was struck with an error which was:
    "330 floppy disk read/write ERROR 4C000046"
    According to the manual 06 or 46 results in an error reading the head with 06 being head 0 and 46 being head 1.
    I have altered many dip switch settings as per the guide and altered the config file half a dozen times and either get drive issues or that read error. if I get drive issues then the floppy emulator doesn't even engage, but with error 46 I can see the Okuma is trying to read the SD card.
    I do see the activity light flash and the screen attempts to start the copy then fails.
    SD card is 2GB standard SD and formatted as fat32 as per HxC instructions.
    I am now at a loss. Any help greatly appreciated.
    Ben
    Jun 2019
    17
    Re: Floppy emulator for an Okuma OSP7000L
    Hello,
    You need to run OSP Reader on a Windows XP computer, then once you've formatted and USB in Floppy disc format, running ODP reader it will format again the device to Okuma format. Then the machine will transfert anything as a floppy is connected.
    Inviato dal mio Mi Note 10 utilizzando Tapatalk
    Mar 2008
    683
    If you are interested I have BTD (behind tape deck) that can be plugged in if it had an old tape punch allowing dnc.
    Mar 2018
    65
    When you tried copying files to the OSP under the edit screen did you enter MS-DOS mode and the use PROGRAM-INPUT?
    Also for the gotek unit I have these setting in my notes taken from this forum...if control unit is OSP7000 , you must use 4 jumpers on MO,S1,JA and JB
    Dave in Ohio
  1. USB Floppy Emulator on Okuma
    By kurmay in forum Okuma
    Last Post: 03-30-2022, 06:20 PM
  2. Okuma OSP7000L Floppy to USB?
    By fishtuna57 in forum Okuma
    Last Post: 07-11-2020, 04:07 PM
  3. floppy to usb emulator help please
    By greggv in forum Haas Mills
    Last Post: 03-29-2016, 03:22 PM
  4. Floppy Emulator
    By ScottTheBruce in forum Toolgrinding / Toolgrinding Machines
    Last Post: 04-01-2015, 06:38 PM
  5. Anyone using a USB / Floppy emulator?
    By JasonR in forum Haas Mills
    Last Post: 09-01-2014, 07:25 PM
