585,914 active members*
3,839 visitors online*
Results 1 to 11 of 11
    Nov 2013
    5
    How do I stop it ?
    My configuration is dm556 + ebay pwm controller. I am trying to get away without microcontroler for my project.
    The question is : is it awailable to incorporate micro switch stop in this configuration that would stop motion when pressed and automatically continues when released.
    One option would be to cut power for controller . But may be there is more elegant solution ?
    Dec 2013
    5717
    Re: How do I stop it ?
    That would work fine.
    You would only need to connect the switch to the enable input.
    Are you sure you want to use a PWM controller? Normal for a stepper drive would be a stepper speed controller some of these also have an enable input that you could connect to your switch.
    An example, not a recommendation: https://www.ebay.com/itm/38375049481...4AAOSwZVlXqa9~
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2013
    5
    Yes I am using one like that. But they used " PWM" in naming , so did I.
    So I need to interupt ENABLE line between controller and driver to stop motion ?
    Dec 2013
    5717
    I think if you connect the Enable + to the Enable - on the drive, it will disable the drive. Yes, a micro switch will work fine. The current is very low.
    Or, there may be an enable on the controller that you can connect to. I would need to see the exact controller to know if that will work.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2013
    5
    Dec 2013
    5717
    EN=ENA=FREE Enable
    PUL=PULS=CLK Pulse
    DIR=CW=CWW Direction
    Common anode Connection method (B)
    EN+ PUL+ DIR+ connect together to com+.
    EN- connect EN
    PUL- connect CLK
    DIR- connect DIR
    Common cathode Connection method (B)
    EN- PUL- DIR- connect together to com-.
    EN+ connect EN
    PUL+ connect CLK
    DIR+ connect DIR
    There is the connection for the micro switch.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2013
    5
    Like that ?
    Dec 2013
    5717
    I think that might work. Try it and confirm. You won't damage anything by wiring it that way even if it does not work in that configuration.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2013
    5
    Thank you for assitance Mr Jim
    IT will take time as parts just ordered but I hope it will work that way.
    Dec 2013
    5717
    My pleasure. It will work some way, but most likely your drawing will work.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2012
    199
    Most of these drives will have the output enabled ( working ) when the EN is not active.
    If you connect the -EN to Gnd and the +EN to +5V the drive will most probably be disabled ( you can easy rotate it by hand )
  1. Replies: 4
    Last Post: 03-10-2018, 07:37 PM
  2. Replies: 1
    Last Post: 01-09-2018, 10:40 PM
  3. Replies: 5
    Last Post: 12-31-2011, 02:29 AM
