585,932 active members*
3,847 visitors online*
IndustryArena Forum > Community Club House > International / Regional Forums > Australia, New Zealand Club House > FS [Sydney, Aus] : heavy transformer and output power supply
    Jun 2010
    4256
    FS: heavy transformer and output power supply
    $40 plus any freight
    This was taken off a functioning CNC machine as more power was needed. The 230 VAC transformer has multiple windings:
    2 off 115 VAC input
    7.5 VAC at 2 A output
    12 VAC at 4.5 A
    17-0-17 VAC at 2 A
    28 VAC at 2.7 A
    40 VAC at 4.5 A
    127 VAC at 4 A
    It has 1.2 m long flexible output leads, a static shield, is approx 160 mm x 80 mm, and weighs ~8.2 kg. Yeah, heavy.
    A power supply tray (about 300 mm wide) made for the transformer is also available with it. It features bridge rectifiers and filter capacitors for 52 VDC, 24 VDC, 12 VDC regulated and 5 VDC regulated outputs. Fuses are included
    on the output lines. Not all transformer windings were used on this tray.
    It can be picked up in Berrilee, NSW. If you want it sent, it would probably have to go by courier at your cost as it is a bit heavy. I am putting it up here as there is no point in advertising it to overseas people (at that weight). And I don't want to just junk it.
    Roger Caffin
    Berrilee NSW
    [email protected]
    Jun 2010
    4256
    Re: FS [Sydney, Aus] : heavy transformer and output power supply
    Transformer still available, but electronics dismantled.
    Cheers
    Roger
  1. Replies: 0
    Last Post: 09-05-2021, 03:11 AM
  2. Ferroresonant transformer for power supply?
    By DennisCNC in forum CNC Machine Related Electronics
    Last Post: 09-04-2012, 04:22 PM
  3. transformer for power supply?
    By drescher3 in forum CNC Machine Related Electronics
    Last Post: 04-22-2012, 05:58 PM
  4. Power Supply Transformer Question
    By snooper in forum CNC Machine Related Electronics
    Last Post: 07-30-2006, 10:38 AM
  5. control transformer to power supply?
    By bobleecnc in forum CNC Machine Related Electronics
    Last Post: 05-20-2006, 02:42 AM
