585,908 active members*
3,816 visitors online*
    Mar 2015
    98
    Z axis height calculation
    Hi when designing your machine in cad and calculating z axis height do I measure from the bottom of the collet to the top of the spoil board or from the end of the drill bit to the top of the spoil board?
    Also 200-250mm isn't too much is it?
    Thank you
    Dec 2013
    5717
    Re: Z axis height calculation
    I would make the bottom position with the collet touching the spoil board. The top position would be the maximum material thickness + the longest tool you will use + another 20 mm or so.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2015
    98
    Thank you
    1222
    200 mm is a lot of travel.Do you really need it?The amount of flex in the machine increases as you increase the Z axis as does the possibility of the gantry flexing since the drive is normally imposed at the base.I suggest you draw the spindle and backplate with a tool in place to see what the limitations will be as you can't get too close to a vertical surface that extends further up than the length of the tool.
  1. Help wiring Tool Height/ Z axis height base into C10 BOB
    By SpecialEd in forum Tormach Personal CNC Mill
    Last Post: 11-21-2016, 02:13 AM
  2. AXIS movement calculation
    By kk85 in forum G-Code Programing
    Last Post: 12-16-2014, 01:38 AM
  3. Replies: 1
    Last Post: 06-07-2013, 04:01 PM
  4. Z axis height as a function of Y-axis position..
    By bo.gardmark in forum PCB milling
    Last Post: 06-07-2012, 07:55 AM
  5. 4 Axis Feedrate Calculation
    By cbr120 in forum MetalWork Discussion
    Last Post: 12-12-2007, 06:20 PM
