585,996 active members*
4,425 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Can't indicate Tool holders on daewoo lathe
    Sep 2005
    273
    This is a 1998 deawoo puma 200 lathe, Had to remove the alignment button on the turret so I could indicate the tool Holders(blocks) in, I guess the machine had been crashed hard but had been fixed, I indicated the turret face, turn tool pocket, and side, the worse i seen was .0015 is that enough to have to pull the alignment buttons to get in line? thanks for any help
    Mar 2009
    1982
    Re: Can't indicate Tool holders on daewoo lathe
    Tolerable if it is below the spindle axis, unacceptable if above.
    "Above" and "below" in regards of spindle rotation direction.
    Sep 2005
    273
    Interesting, thanks for the reply
  1. make Lathe tool holders
    By Warrrenkcash in forum Australia, New Zealand Club House
    Last Post: 11-17-2019, 09:19 PM
  2. Multifix Lathe Tool Holders from Createtool
    By datac in forum Uncategorised MetalWorking Machines
    Last Post: 12-31-2015, 06:33 AM
  3. Two tool holders for lathe
    By alex_ku in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-03-2013, 01:14 PM
  4. Tool holders for Daewoo lathe turret?
    By Chuck Reamer in forum CNC Tooling
    Last Post: 01-01-2008, 01:14 PM
  5. Tool Holders for a Lathe
    By javajesus in forum Uncategorised MetalWorking Machines
    Last Post: 12-01-2007, 05:11 PM
