585,987 active members*
4,200 visitors online*
    Dec 2011
    15
    Good cnc lathe controller
    I might be looking at putting a new control system on a lathe I have.
    Any one have any suggestions on a good control?
    I have several centroids. Good control, lacking on conversational programming and speed.
    I know the Mach 3,4 stuff is junk. I need a pro level system.
    Fanuc & Siemens are pricey and have zero support.
    Dec 2013
    5717
    Re: Good cnc lathe controller
    I sent you a PM.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2009
    1982
    Depends on what exactly you need to control. What safety system you want to implement? What are drives: spindle; X axis, Z axis. Is there any gearbox? What is hydraulic system? Parts catcher, bar pusher? What is turret drive and many other factors. I would start to see the encoders first and desice if I leave them as is or I will upgrade. Motor drives - the same story. Is it better to install new ones or leave present.
    Evaluate availability of new hardware components. Then you can figure out what the control specification will be - how many analog signals, what buses, how many digital inputs / outputs.
    I would say the Linuc CNC is quite flexible if you are not afraid to dig deep into operating system.
    Sep 2011
    23
    Do any retrofits have good conversational programming?
  1. a good cnc router controller board!!
    By Kjellarnem in forum Hobbycnc (Products)
    Last Post: 09-23-2013, 04:39 PM
  2. CNC bport clone, dead controller- good servos
    By lkasdorf in forum Servo Motors / Drives
    Last Post: 10-04-2011, 10:19 PM
  3. Is this a good quality lathe and controller?
    By koja1963 in forum Uncategorised MetalWorking Machines
    Last Post: 03-30-2008, 01:29 AM
  4. Need a Good CNC Lathe Book
    By Crashmaster in forum Uncategorised MetalWorking Machines
    Last Post: 05-29-2007, 09:53 PM
  5. this lathe good to cnc?
    By heilcnc in forum Mini Lathe
    Last Post: 01-21-2007, 01:54 AM
