585,758 active members*
4,568 visitors online*
    Sep 2015
    150 w RECI LASER TUBE burns a circle not a dot
    Hi there,
    It hasn't engraved right for a week. So i went to realign it. I taped the second mirror, nothing was visible on the tape. So i taped the first mirror, this is what i get.
    what do you think the issue is?
    Ps: When i first got it, it burned a hole out of the tape and cardboard.
    Thank you.
    Nov 2008
    644
    Re: 150 w RECI LASER TUBE burns a circle not a dot
    I had the same pattern and replaced the tube. I had a low cost tube and assumed it couldn’t be repaired. Problem is that it won’t focus properly
    I believed it was from lack of coolant.
    Dec 2006
    124
    I contacted RECI on this 150 watt tube's burn and their response was that the gas was consumed and that a replacement tube was needed.
    You could also use a CO2 laser power meter probe (like Mahoney brand) and measure the output power.
    Also, I would visually inspect my RECI 150 watt tube's visible light illuminated in the tube during operation to see if anything else was going on (I had two of its power supplies fail on me), and also at lunch time my AC voltage varied from regular working hours (as my neighbor's were all machine shops and powered down at lunch)--I lost 5-10 volts and the output power fluctuated wildly due to the power supply's circuitry.
  1. 150 W RECI laser
    By chuck767 in forum Laser Hardware
    Last Post: 04-27-2019, 04:22 PM
  2. Shenhui (RECI 150 watt tube) not going through entire tube. Sparks!
    By stonepercussion in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-12-2017, 07:40 AM
  3. poor power on 100w reci tube. tube is new. 1290 laser.
    By nate in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-05-2015, 07:31 PM
  4. Laser 150 W RECI laser tube, monster!!!!
    By lamicron in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-13-2014, 06:06 PM
  5. Old Reci Laser Tube
    By vashadow in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-02-2011, 08:41 PM
