585,744 active members*
5,133 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Trapezoidal Coarse Thread DIN 103 in Mastercam
    Mar 2020
    Smile Trapezoidal Coarse Thread DIN 103 in Mastercam
    Hello all ! I would like to make external threading (shaft) of trapezodial thread in DIN standard size (or ISO, ist the same), dia 100 x 12 , DIN 103. My mastercam does not have any inserts to suit this need, I also do not find any possibility to make new custom insert (for example from Seco dxf geometry according to catalog insert : SECO 26ER10.0TR CP500 ).
    Thank you guys !
    Mar 2008
    683
    Re: Trapezoidal Coarse Thread DIN 103 in Mastercam
    Drive the cutter on the center of the tool and run on a wireframe helix.
  1. Trapezoidal thread issues
    By chris-bond in forum Mechanical Calculations/Engineering Design
    Last Post: 11-18-2020, 10:26 AM
  2. Trapezoidal Thread cutting
    By gamazard in forum MetalWork Discussion
    Last Post: 12-04-2016, 05:35 PM
  3. mill a trapezoidal thread
    By matzeKlueber in forum Milling
    Last Post: 03-26-2012, 06:33 AM
  4. deburr internal trapezoidal thread
    By fjmoehle in forum Milling
    Last Post: 01-29-2012, 12:18 PM
  5. Trapezoidal thread
    By Reiko in forum HEIDENHAIN -> MillPlus
    Last Post: 06-25-2008, 05:29 PM
