Originally Posted by
crclark
I have a small VMC that came with no NC, it has a Baldor servo motor for the spindle with a resolver. The drive is a Microflex, I have done the auto tune with the Mint software but I need to get some sort of "orientate" because the spindle is a BT30 and has a carousel ATC. The spindle is driven at 2:1, large pulley on the motor and small pulley on the spindle. I believe the drive ratio will work because the index pulse will be half of the rotations of the spindle.
I need to find out if I can use the Analog +/-10VDC with maybe a input to get the spindle to orientate for the ATC, the drive has 3 operation modes. Speed, position and torque I think.
If I can get the spindle to orientate how do I set that position. Is there a setting in the drive to set the 2:1 drive ratio?
Thanks in advance
