586,005 active members*
5,256 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > CNC Plasma / Oxy Fuel Cutting Machines > Best way to get a 100:1 arc voltage out of Powermax 85
    I'm surprised I can't find anywhere this has been mentioned before here, but I have searched up and down and can't find it, so...
    What's the simplest and/or best way to get a 100:1 signal from a Powermax 85 divider board?
    I realize a 100:1 signal is not the best to use but I'd still like to know.
    Nov 2013
    4372
    Re: Best way to get a 100:1 arc voltage out of Powermax 85
    Hypertherm machines typically have a 50:1 divider. If you really must have a 100:1 then just add a 2:1 divider at the output of the 50:1.
    Craig
  1. Raw Arc Voltage Points on Powermax 1100
    By Donn in forum Hypertherm Plasma
    Last Post: 01-17-2016, 08:22 PM
  2. Powermax 85 torch loses arc
    By esp173 in forum Hypertherm Plasma
    Last Post: 09-24-2015, 07:22 AM
  3. Powermax 45 intermittent arc loss
    By drumsticksplint in forum Hypertherm Plasma
    Last Post: 04-19-2014, 10:55 PM
  4. Powermax 45, arc stops after pierce intermittently
    By DirtBound in forum Hypertherm Plasma
    Last Post: 01-24-2014, 07:38 PM
