584,863 active members*
5,079 visitors online*
    Mar 2015
    98
    longest tool bits you can use
    trying to figure out a few problems here
    if i am cutting into 200mm thick soft wood which is my maximum cutting height and cutting 3d that goes up to 150mm deep then that means the z axis plate and spindle is going to hit the material. i can counter act this by using longer tool bits and having the spindle lower. what is the longest tool bit you can get for 3d carving? i know a strong rigid machine is needed and strong motors.
    thanks
    Dec 2013
    5717
    Re: longest tool bits you can use
    Harvey tool is one source https://www.harveytool.com/products/...ra-long-length
    They have long end mills in all shapes and sizes.
    Jim Dawson
    Sandy, Oregon, USA
  1. Longest Endmill on PC1100
    By jmvar in forum Tormach Personal CNC Mill
    Last Post: 03-14-2016, 08:33 PM
  2. Longest possible drillable hole
    By scarlaton in forum Uncategorised MetalWorking Machines
    Last Post: 04-03-2014, 09:42 PM
  3. longest Z axis?
    By rabidhamster in forum DIY CNC Router Table Machines
    Last Post: 05-12-2012, 02:12 AM
  4. About longest Axis
    By samsagaz in forum DIY CNC Router Table Machines
    Last Post: 01-15-2012, 04:30 PM
  5. Longest running project
    By ger21 in forum WoodWorking Topics
    Last Post: 05-29-2011, 09:28 PM
