585,978 active members*
4,298 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > X7 accuracy measured with CMM
Results 1 to 6 of 6
    Mar 2019
    34
    just posted a new video machining a small part on the X7 and then measuring the part with a CMM. Includes video of the CMM and the print out of the results.
    https://youtu.be/fQDWVgrF_8E
    Sent from my iPad using Tapatalk Pro
    Re: X7 accuracy measured with CMM
    Thanks again for another great video! May I make a suggestion/request for the next video..? If you are up to it, can you go over the machine maintenance and lubrication systems?
    Mar 2019
    34
    Quote Originally Posted by sportbob06 View Post
    No problem! I’ll add it to the list.
    Mar 2012
    189
    If you are taking requests I would be interested in seeing a walkthrough of getting chips out of the enclosure. washdown to the chip bin and removal of it. Too bad Syil didn't give you a deal on the machine to make content since you are one of few making content specifically about the machine.
    -Jon
    Mar 2019
    34
    Quote Originally Posted by maker of things View Post
    Sure I’ll take requests. My machine shipped without the wash down hose so I’m still waiting on it. Should have it shortly however. I’ll do a video on installing it and then clean the machine out when time permits.
    Apr 2006
    844
    Nice
    Direction,Commitment,Follow through
  1. Replies: 0
    Last Post: 02-08-2019, 11:25 PM
  2. I have some parts I need measured up a bit on a CMM
    By Brian FRF in forum RFQ (Request for Quote)
    Last Post: 08-22-2013, 07:55 PM
  3. d and h offsets with measured tools
    By Magpie73 in forum Fanuc
    Last Post: 05-25-2012, 02:06 PM
  4. Measured rigidity of home-built machines
    By JerryBurks in forum CNC Wood Router Project Log
    Last Post: 09-12-2011, 04:38 PM
