586,005 active members*
4,979 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Colchester Tornado 200 Fanuc OT Control - Turret indexing problem
Results 1 to 12 of 12
    Aug 2007
    3
    Machine year: 1996.
    When the machine is running for about 2 hours, the turret is mis-indexing like its running off the top of the snail cam. I now have the turret indexing forward and reverse to try and solve the problem. Is there a parameter to slow down turret indexing as the turret appears to be bouncing when pulling back in to lock position?
    Any help would be greatly appreciated.
    John
    May 2006
    82
    Hi John !
    You are right ! there is a parameter but i don't know wich is.
    sorry i do not what you mean :"running off the top of the snail cam"
    I have some experince with Duplomatic Turret BSA 200 I would be glad to help you , how your turrets fails:
    Rotaring CW or CCW
    Or does it fail on both directions?
    what alarms appears?
    Nov 2005
    219
    Quote Originally Posted by JohnWD View Post
    Machine year: 1996.
    John
    Is the turret balanced very well with the weight of the tools???
    mine bounces too and sometimes it does not lock in. It is because the turret is unbalanced but we have very few other choices.
    Aug 2007
    3
    @ cncatj:
    The turret fails in both directions. I have a turret specialist coming to factory on Wednesday 18th, will let you know result.
    Thanks for your reply! :cheers:
    - John
    @theemudracer:
    Turret is balanced well, but still having problems. It appears to be solenoid or something overheating after a couple of hours, may be a fault with resistors overheating.
    Will let you know if the specialist solves the problem, it may be of some use to you.
    Thanks for your time.
    - John
    This is which type of Turret, Electrical or Hydraulic. Normally in colchester They are using Duplomatis or Statur Electric turrets. I think it is positioning problem Pl. checkup the Position coder Signal. Normally the sequence of the Turret operation is like this
    1) Turret rotate CW or CCW
    2) Position signal from the position coder
    3) Position Locking by solenoid coil
    4) You have to get Clamping signal
    5) Motor Off & locking pin solenoid OFF
    Pl. check the above sequence & Explain the problem in detail, Then only we can give Suggestions.
    Aug 2007
    3
    Hi guys, I had a turret specialist (who worked for Colchester and is very familiar with Duplomatic turrets) check the turret. He said the turret itself is okay, but he had encountered this type of problem before and reckons the 110v transformer is overheating. I'm checking this out. Possibly replacing transformer with a bigger one. I've run it with a regular stand-alone fan aimed at the transformer and it worked fine, but when I did the same job today without the fan the machine kept shutting down.
    I'll try a few more things and let you know how I get on. Thanks again for your time.
    - John
    May 2006
    82
    O.K John !
    What i did once on a tornado lathe was:
    install a separate 24v Power supply for the turret soleniod brake only
    Before this there was a lot of problems with this lathe.
    Can you post an inside picture of the machine electrical panel
    Here i have 2 types.
    Jul 2008
    37
    Fanuc OT Manuals Needed (Cholchester Tornado 200)
    I'm urgently in need of Wiring Diagrams for Colchester Tornado 200 with Barfeed.
    Could sb help me ?
    tnx in advance
    jalal
    May 2006
    82
    Hi , mte jalal:
    What is wrong with your machine?
    Jul 2008
    37
    hi,
    In fact when I power up control, there control keyboard keys are not blinking and Hydraulic system is not working.
    it's giving some errors for Turret.
    the problem is that we can not find why there is no power on control.
    tnx
    May 2006
    82
    O.K I see.
    In my opinion
    There are 2 posibble causes :
    1- Turret crash Switch its activated
    2- E-stop board is defective
    Oct 2012
    colchester tornado 200 lathe when powering up comes up with error 1026 filter blocked. the machine has just been moved to our factory. any pointers in the right direction.
    regards
    neil
  1. Colchester Tornado Fanuc 21i-t
    By Stebedeff in forum Fanuc
    Last Post: 11-08-2010, 02:43 AM
  2. Problem with Fanuc control
    By mccafferty in forum Fanuc
    Last Post: 05-28-2007, 08:01 PM
  3. Turret Not Indexing
    By rajesh_1355 in forum Fanuc
    Last Post: 02-24-2007, 06:25 PM
  4. Fanuc control problem
    By wilsontool in forum Fanuc
    Last Post: 10-12-2006, 07:56 PM
  5. Takisawa TS-10 Indexing Problem
    By chriztopia in forum Uncategorised MetalWorking Machines
    Last Post: 09-25-2006, 02:30 PM
