585,729 active members*
4,928 visitors online*
    Mar 2015
    8
    Getting My Head Round Zeroing
    Trying to get my head around how to engrave on my Laser then outline cut on the cnc router? I'm not sure if you Laser first then move to cnc or the other way about. If I put a location mark and zero both from that point would that work? Just not sure how to go about this.
    15362
    Re: Getting My Head Round Zeroing
    Quote Originally Posted by hootsmangreen View Post
    To set it up you would use one of the corners, as long as that is you X0 Y0. and have the same in your drawing and Cam software, you should be good to go, machine first.
    Mactec54
    Mar 2015
    8
    Many thanks Mac
    Colin
    24220
    If you need to set up a work jig etc coordinate system, look at G54-G59
    Albert E.
    Jun 2020
    7
    How many of these products do you need to make? If a single copy, you can light it through the film and then etch it in acid
  1. Colchester Triumph 7.5" (Round Head) Lathe
    By jim_cliff11 in forum Uncategorised MetalWorking Machines
    Last Post: 04-06-2019, 02:53 PM
  2. Replies: 5
    Last Post: 04-16-2012, 09:25 AM
  3. round ram head
    By locoind in forum Bridgeport / Hardinge Mills
    Last Post: 04-21-2006, 03:44 AM
