586,005 active members*
4,861 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Changing co-ordinates
    Sep 2012
    216
    G'day all,
    I've just started playing around with Solid works 2014. I've drawn a part that i want to make but probably went about it wrong and i need to change the co-ordinates for when i do the cam program. At the moment i have the tool coming in from the side where i need it at the top. I can't seem to get it to change to where i need it. I'm guessing that it is actually possible without redrawing the whole thing.
    I will have more questions later I'm sure.
    Cheers
    Bob
    Regards Bob
    24221
    Re: Changing co-ordinates
    Set up G54- G59, work offset?
    Albert E.
    Mar 2008
    683
    Quote Originally Posted by sudsy View Post
    G'day all,
    Cheers
    Bob
    There are two things going on. There are setting up the coordinates in your CAM package and there are setting up coordinates in Solidworks.
    In Solidworks use the "REFERENCE GEOMETRY -> COORDINATE SYSTEM"
    In your CAM package use the part / job setup dialogue to create a new coordinate system or chose the new coordinate system you created in Solidworks.
    Sep 2012
    216
    Thanks for the replies. I think i've got the hang of drawing on the correct planes for orientation to the mill. Now just have to practice
    Regards Bob
  1. Plotting x-y co ordinates between two points with known radious
    By Ste1070 in forum Education - Teachers and Students Hangout
    Last Post: 01-07-2019, 02:18 PM
  2. NEED URGENT HELP IN RESETTING MACHINE CO ORDINATES
    By agrv8dcutting in forum Australia, New Zealand Club House
    Last Post: 11-09-2016, 08:33 PM
  3. Help! - Using multiple work co-ordinates? X4
    By colton_m in forum Mastercam
    Last Post: 10-15-2010, 06:06 AM
  4. GCode differs to Drawing Co-Ordinates
    By Kiwi in forum BobCad-Cam
    Last Post: 07-02-2008, 02:34 PM
  5. world, view co-ordinates
    By cadman in forum Surfcam
    Last Post: 08-03-2005, 08:05 PM
