585,886 active members*
6,259 visitors online*
    Aug 2005
    witch CAD/CAM software with MACH3 ??
    Witch cam software do you use with Mach3 ?
    I tried with Solidworks 2007 and camworks, but i can't get it to work properly...
    A circle in a square drawing results in a circle out of the square...
    i can't find a postprocessor that works togetter with mach3.
    In Bobcad can i get it to work, but the dimensions don't fit with the drawing...
    Thanks in advance,
    Ronny
    Sep 2009
    72
    i have the same problem!
    Sep 2007
    359
    Mach3 must be set-up correctly.
    You must have a suitable post processor.
    This would apply to any software CNC & Cad/Cam combination
    Post your incorrect code and then someone with Mach3 can load it to Mach3 and see where the problem lies
    Phil
    Sep 2009
    72
    thanks Phil, but the postprocessors are for the CAM or for the mach3, what i understand is thet they are for CAM software, so the CAm can generate a suitable code for a specified control software, im i wrong?
    Apr 2004
    5737
    The Post Processors are part of the CAM software
    Since CAM programs have to be able to write code for a wide variety of machines, which work differently depending on their control software, it's important for the CAM program to have a postprocessor that translates the generic code it writes into a version that will work correctly with the particular machine control you use. If you're using Mach3, then you should choose a Mach3 compatible postprocessor. If your software doesn't have one, try a Fanuc post - that should get you close, but be prepared for errors in some G-code functions, such as how circles and arcs are defined.
    Andrew Werby
    www.computersculpture.com
    Quote Originally Posted by absolutepoker01 View Post
  1. DynaMite 2800 & Mach3 software
    By ffulmer in forum Mach Mill
    Last Post: 01-20-2019, 04:45 AM
  2. Witch milling machine to buy for CNC retrofit?
    By Sperstad in forum Vertical Mill, Lathe Project Log
    Last Post: 02-10-2007, 05:21 AM
  3. Witch stepper motor?
    By Marc in forum Stepper Motors / Drives
    Last Post: 05-10-2005, 07:58 PM
  4. solidworks/ Mastercam witch one !!!!
    By craftech in forum Mastercam
    Last Post: 01-16-2005, 05:11 PM
