585,741 active members*
5,401 visitors online*
Thread: DM2400 Parts
Results 1 to 3 of 3
    Sep 2005
    6
    DM2400 Parts
    Hi All-
    After several years of running my trusty DM2400 as mostly stock, something is starting to have some problems. I first noticed it on an END NEWPART operation where the unit would fail to return to the home position. Power cycling will temporarily “fix” it. Fix is not the right word, but at least I can continue making parts. I have not seen it fail while actually making a cut, at least that is nice.
    I have also seen it fail on initialization and say something like “Z AXIS STUCK” or “Y AXIS STUCK”. The Y axis has always had quite a bit more backlash than the X and Z. I don’t know if that is relevant.
    Third symptom I have seen is that in manual mode, running at high speed (30 in/min or whatever the highest speed is), the Y axis loses step count. I have not seen any problems with X or Z in manual mode.
    I am thinking that either the steppers are dying or perhaps the step drivers. I’m more inclined to blame the motors, as they are old and have moving parts.
    So… do any of you that have converted a 2400 to something more modern have a box of parts that you would be willing to sell?
    Otherwise, it’ll be a new adventure to go down the full conversion path.
    Thanks for any advice/help!
    -Eric
    Sep 2021
    8
    Re: DM2400 Parts
    I have a Dyna 2200 that was donated to me. I am in the process of working on the electronics. I am building myself a new controller running an arduino uno with a Raspberry Pi. I plan to use the existing stepper drivers, but it is my understanding that the 2200 controllers will work on a 2400, if you need one.
    Sep 2021
    8
    Re: DM2400 Parts
    Attached is some information on the steppers used in the 2400.
  1. Dm2400 Re-wire
    By EngraverGar in forum Dyna Mechtronics
    Last Post: 07-31-2018, 02:41 PM
  2. Replies: 0
    Last Post: 03-13-2018, 06:33 AM
  3. DM2400 parts for sale
    By cyclotron in forum Dyna Mechtronics
    Last Post: 12-22-2013, 01:08 AM
  4. Dyna DM2400 Parts for sale!
    By Fastest1 in forum Dyna Mechtronics
    Last Post: 05-27-2011, 01:25 PM
  5. Dyna DM2400 - need controller,parts
    By base2 in forum Benchtop Machines
    Last Post: 07-16-2009, 01:19 AM
