Originally Posted by
gisbertz
Tried it a couple of times already. No use. Maybe an end-switch that isn't working anymore?
Often there is a e-stop overide P.B. that will over ride the overtravel limits, can you here or see a e-stop relay or contactor pick up when the e-stop is released or the control start button, if you have one?
If there is a external fault like overtravel switch then it will drop out when the button is released.
Did you get schematics with the machine?
Al.
Albert E.
