Hi all,
Has anyone got a complete list of system variables, (VS), for the Okuma OSP300 control they can pass to me please.
I'm trying to control the tool measure in cycle for new tools via the "USE" toggle.
Cheers in advance
Alan
Hi all,
Cheers in advance
Alan
Look at this list
https://www.hartwiginc.com/learning-...-okuma-lathes/
"Imagination is more important than knowledge."
hy if you look for VS+ :
... a-z, then check attached list of system variables
... 0-9, then you will need to dig the msb files, or look through the manuals; those are not system variable, but kind of a mix type, between common/array and local; however, they allow acces to data for measuring cycles and probes, allowing one, for example, to custom build a gauging cycle
for more details, please be specific / kindly
