as above does anyone on here use a ballscrew and a rotating ball nut? just looking for ideas on how to fix the ballscrew both ends and i cant seem to find any examples anywhere.
thanks
thanks
You would have to machine a P-Clamp, that would fasten to the Plate. if you want or need to tension the Screw, then you would have the same P-Clamp mount and Drill and tap the ends or the Screw
There is very little Tension needed on the Screw, depending how long the normal is only 4 to 6 ft.lbs.
The accuracy alignment of the Screw with the linear Rail is very important
Mactec54
