No matter how many times I try, every time I want to change a tool or machine parmeters in the cam set up wizard, it will not correctly repost what I put in. Let's say I select start cam job and go to machine settings in cnc set up and put in my machine max speeds and feeds(1,000 IPM and 10,000 RPM).
It gives me the correct IPM but the RPM is 254,000 for my max speed.
And on my tool parameters, If I try to put in a feed rate lower than is already defined and try to save that tool and parameters if always revets back to the original chip load. Any advise?
