Has anyone seen a 770 motor (1.5hp) retrofitted to a 440?
Any idea if the VFD needs to be swapped? Any other components that would need to change?
Needing to switch to the low speed setting to drill with the stock 0.75hp motor is a pain. At 10k with small tooling the machine does well otherwise.
I think doubling the power with the 770 motor would be a big upgrade.
