585,760 active members*
3,975 visitors online*
    Apr 2012
    91
    CNC router to hot wire cutter
    I have a 6ft x 3ft router. Can it be usefully converted, with an addon, to hot wire r.c. plane airfoils.
    Any practical guidance would be appreciated.
    1218
    Re: CNC router to hot wire cutter
    From the screen name it appears we could be near neighbours.I haven't any advice about converting a router to hot wire cutter but I have cut several aerofoils manually with a hand held device.I believe Stefano Duranti's software will generate the code for the foil sections in the database.What my be a challenge will be arranging for the secondary end of the mechanism to (a) exist and (b) apply the correct tension for wires of various lengths.I don't know if you have found this website yet https://rckeith.co.uk/free-linuxcnc-...ds-ox-router/# . There is good deal of information there.
    Apr 2012
    91
    Thanks for reply, looked at Keith`s site, most interesting.
    I am born and bred Eaton Bray. Are you familiar with it? Not living there now, but have been for some years living in Hampshire.
    Have been milling a couple of foam fuse`s but it makes quite a mess. So was this morning looking at rigging up some kind of cnc wire cutter..
    1218
    Good luck with the project.It seems we were referring to different Eatons.
  1. DIY CNC Hot Wire Cutter
    By koko97 in forum CNC Wire Foam Cutter Machines
    Last Post: 11-07-2015, 02:15 PM
  2. New hot wire cnc cutter
    By wantacnc in forum CNC Wire Foam Cutter Machines
    Last Post: 02-05-2015, 03:36 AM
  3. First CNC Hot Wire Foam Cutter
    By TiboJ in forum CNC Wire Foam Cutter Machines
    Last Post: 12-08-2013, 05:06 PM
  4. What 4 axis CNC hot wire cutter to buy?
    By Snowy in forum CNC Wire Foam Cutter Machines
    Last Post: 12-08-2011, 01:18 AM
  5. CNC Hot wire Foam Cutter
    By Krashlnd in forum CNC Wire Foam Cutter Machines
    Last Post: 01-17-2006, 02:57 AM
