585,994 active members*
4,692 visitors online*
Thread: Pipework
    Oct 2021
    Pipework
    Hi All, I'm in a factory that runs two large waterjet machines and we constantly have problems of leaks from pipework (elbows mainly). I wonder if anyone has had similar problems and found a unique solution like replacing all the high pressure pipes to have the minimal number of fittings on, or a great tool for honing and threading pipe that was foolproof ( we currently use some quality tools in a battery drill for honing and threading, but I'd prefer a decent hand tool set)
    Jan 2020
    47
    Re: Pipework
    The cone and seat part are critical. We use tools from Alfi waterjet they sell a quality kit. When assembling your high pressure parts it's important to have a minimum off three threads showing after the nut otherwise you won't get the compression on the pipe.
    - - - Updated - - -
