585,975 active members*
4,496 visitors online*
    Oct 2017
    18
    Kflop <-> Mach3 communication
    well... i looking for KFLOP to/from Match3 communication but the process is not well documented.
    I tried to create a command in the Notification thread with user.Persistent[] variable with enum SPIN_ON, SPIN_OFF, FLOW_ON etc. and this working fine, but if i want to create a my library of command, how to do?
    For example: Launch a personalizated M.x macro and to intercept it in KFLOP Thread.
    I looked at some examples and there are "strange" number as 10300, 10301 and so on, but these number are not documented.
    Is there any document that describes the use of these messages?
    Guido from Italy
    May 2006
    4045
    Re: Kflop <-> Mach3 communication
    Hi Guido,
    Mach3 NotifyPlugin() message numbers 10000 - 10999 are passed through to your Notify Program as described here. Which numbers you use is up to you.
    HTH
    TK
    http://dynomotion.com
    Oct 2017
    18
    Damn! This document escaped me.
    Seems to be very simple!
    Thanks very much Tom
  1. KFLOP with Mach3 and c-programming
    By Lozzy in forum Dynomotion/Kflop/Kanalog
    Last Post: 07-28-2016, 04:38 AM
  2. Virtual COM Port - Communication between PC and KFLOP board
    By kure6592 in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-30-2014, 06:56 AM
  3. Mach3 vs Kflop
    By MarunovV in forum Dynomotion/Kflop/Kanalog
    Last Post: 07-25-2012, 08:54 PM
  4. communication problem between mach3 and pc
    By ataxy in forum Mach Software (ArtSoft software)
    Last Post: 01-22-2008, 01:36 AM
  5. Mach3 Communication for Development ?
    By tvdbon in forum Mach Software (ArtSoft software)
    Last Post: 12-11-2007, 02:08 AM
