585,712 active members*
4,234 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Control Software > Trying to compile Grbl esp-32 Barton Dring and failing
Results 1 to 3 of 3
    Oct 2021
    Hi, hopefully someone will be able to help me out here. I've tried on the Espressif forums and had no luck, similarly on GitHub.
    I came across this site :https://embeddedtronicsblog.wordpres...10/esp32-grbl/
    and followed the instructions explicitly - couldn't get it to compile.
    I tried similar tutorials on Youtube and a common factor seems to be the need for the file 'FreeRTOS.h".
    I tracked down the code for FreeRTOS.h, or so I thought, pasted it into a Notepad++ document and placed it in the same directory as I2SOut.cpp which appeared to be the villain of the piece.
    Still no joy.
    I'm using a Wemos D1 R32 with a cnc shield v3, and by all accounts the Arduino IDE sees this board as an Esp32Dev.
    I'm not in the first flush of youth but not totally daft and this has me baffled.
    If someone can help me with this it would be wonderful, in fact if someone could provide a Hex file I could just flash the board with that would be like Christmas!
    Thanks for your patience, regards, Redeemed.
    Oct 2010
    19
    Re: Trying to compile Grbl esp-32 Barton Dring and failing
    Have you tried the grbl_esp32 wiki?
    Oct 2021
    Hi Kirk, fancy you not being on the Sainsmart FB group ;-)
    It turns out if you use VScode and PlatformIO it compiles like a charm!
  1. Replies: 1
    Last Post: 08-19-2016, 11:57 AM
  2. Help to save esp as dwg
    By cutteredge in forum Esprit
    Last Post: 12-09-2014, 04:09 PM
  3. om-A 1003 ESP OR OT alarm?
    By landslide1 in forum Fanuc
    Last Post: 01-25-2013, 12:09 PM
  4. ESP Forest
    By daza in forum Musical Instrument Design and Construction
    Last Post: 11-18-2010, 05:13 PM
  5. EMC 2 compile?
    By mkonci1 in forum LinuxCNC (formerly EMC2)
    Last Post: 04-12-2006, 08:21 AM
