586,009 active members*
4,781 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Marine-Grade Moisture-Resistant Polyethylene (HDPE) Sheet
    Apr 2003
    95
    Hello Group, I am looking at a project that would require machining parts out of "Marine-Grade Moisture-Resistant Polyethylene (HDPE) Sheet". I have never machined this material before and was wondering if it is easy to machine? Would I use the same speed and feeds as I would machining acrylic? Another thought would be laser cutting these and would it be safe?
    Thank you,
    Eric
    Dec 2013
    5717
    Re: Marine-Grade Moisture-Resistant Polyethylene (HDPE) Sheet
    It machines better than acrylic, pretty much like butter. Very forgiving. Maybe a bit higher feed rates than acrylic would be better.
    Jim Dawson
    Sandy, Oregon, USA
    1225
    One word of caution,If you machine pockets or tapers,it does tend to curl up a bit as the internal stresses are relieved.As for speed,I had cut various rebates and corner radii with a hand router on a good number of parts before trying the material on a CNC.Since the finish was good I used similar speeds and it worked.
    Apr 2003
    95
    Thanks Jim Dawson and routalot that helps me alot!
    Eric
    Nov 2013
    4372
    I've always struggled with HDPE, its soft enough but forms long curls rather than chips. It's also very prone to re-melting and welding itself
    back to the parent material. Careful choice of feeds and speeds are required, and I find flood cooling helps with the heat problem.
    Cutting in small discrete steps, a bit like peck drilling maybe helpful too.
    Craig
  1. Machining High Density Polyethylene (HDPE)
    By Sbthomas13 in forum Glass, Plastic and Stone
    Last Post: 09-14-2019, 11:31 AM
  2. Replies: 1
    Last Post: 12-26-2014, 05:24 PM
  3. Most suitable bit for aircraft grade aluminium sheet
    By ajfoxy in forum Australia, New Zealand Club House
    Last Post: 08-30-2014, 12:48 PM
  4. Engraving Grade 50 Sheet Steel
    By racecraft in forum MetalWork Discussion
    Last Post: 01-22-2010, 11:36 PM
  5. Has anybody used "Boatboard" (marine HDPE) before?
    By CanSir in forum Joes CNC Model 2006
    Last Post: 07-13-2008, 12:30 PM
