585,975 active members*
4,614 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Space Between Cuts, Nesting, Securing
    Oct 2021
    Hi, new to CNC milling.
    1. Is there a standard rule for how much space should be left between cuts?
    2. Is there a standard rule for the space left between a cut and the outer edge of the stock panel?
    3. As we cut, some of the stock panel releases from the base sheet. What is the best way to keep our stock sheet on top of our base sheet?
    Materials used in our shop include 3mm brushed aluminum and white aluminum panels, and 1/4" bamboo panels.
    Bit size is 1/4" diameter.
    Machine is an Industrial CNC (company name)
    Software: SketchUp Pro -> BobCAD-CAM -> Mach3
    Thanks so much.
    Aug 2020
    Re: Space Between Cuts, Nesting, Securing
    happy wheels is a fun game to play with family and friends.
  1. securing a spoilboard
    By podzilla in forum Commercial CNC Wood Routers
    Last Post: 12-11-2018, 06:35 PM
  2. Nesting around previous cuts
    By cncmadness in forum PhotoVCarve and VCarve Pro
    Last Post: 12-14-2014, 07:24 PM
  3. Ballscrew securing
    By fragger6662000 in forum Benchtop Machines
    Last Post: 02-13-2011, 09:27 AM
  4. Securing the material
    By darkling27 in forum WoodWorking Topics
    Last Post: 04-27-2010, 05:12 PM
  5. Paper space Model space ??
    By cncadmin in forum Autodesk
    Last Post: 05-29-2003, 12:07 PM
