ATC CNC router is an intelligent CNC machine with automatic tool changing spindle and auto tool magazine. When working, CNC tools can be automatically replaced according to work requirements, without manual operation, and greatly improve work efficiency. There are two types of CNC ATC kits, including linear Automatic Tool Changer CNC and disk Automatic Tool Changer CNC. The tool magazine can carry 4-12 pieces of different tools.
The CNC engraving machine AKM1325C is ACCTEK's best-selling ATC CNC router. It plays an important role in many engraving industries such as the furniture industry, advertising industry, and handicraft processing. The main accessories of the CNC engraving machine AKM1325 are from global well-known brand suppliers, ensuring that the machine has good performance when it is working. The following is the configuration and characteristics of this CNC router, you can better understand the function of this machine, it is of great help for choosing the right CNC engraving machine.
ACCTEK ATC CNC router chooses 9.0KW Chinese famous brand HQD or Italian HSD air-cooled spindle. No water pump is needed, so it is very convenient to use. It can ensure long-term stable work and longer service life. For the automatic tool changer cnc router machine, the ATC spindle is the core component of the machine. The efficiency of the spindle affects the processing. The high-power spindle cuts faster and the workpieces processed are better.
ATC CNC router
The auto tool changer is divided into ATC linear tool changer and ATC carousel tool changer. The standard configuration is an ISO 30 tool holder, which can be with 20mm max.diameter tools. When the machine is working, the tool can be changed quickly and reliably according to the system settings, which saves a lot of time and improves the efficiency of material processing. Very suitable for complex large-scale engraving processing. The standard configuration of the CNC engraving machine AKM1325C is 8 tools. If you are in the advertising industry, you can choose a small cnc. 4 tools can usually meet your processing needs.
In addition to the automatic tool change system, our ATC CNC Router is also equipped with Taiwan Delta and Japan Yaskawa servo motors, which makes CNC engraving machines with tool change machining centers have the advantages of low noise, high speed and high positioning accuracy. In the same time, it provides more efficient work than ordinary engraving equipment. The ATC CNC router can complete a variety of carving techniques such as contours, curves, and hollows, so that the product exhibits a unique design style.
The ATC CNC router AKM1325 uses a T-slot and vacuum dual-purpose worktable. The T-slot table can use clamps to fix small materials; the vacuum table can use vacuum adsorption to fix large materials, which is more convenient, simple and efficient. This woodworking cnc router is also equipped with 3.0KW double bags dust collector. When the CNC router is working, the dust-proof brush on the spindle to control all the sawdust residues in a small range, and then debris is sucked into the vacuum cleaner. It not only ensures the cleanliness of the working environment, but also benefits the health of the staff.
