585,981 active members*
4,582 visitors online*
IndustryArena Forum > CAM Software > PowerMILL > 4 axis toolpath strategy needed to do the edges with a V-shape tool
Results 1 to 3 of 3
    Mar 2020
    8
    I have this model (please see attached) and want to mill the selected surface, but for the edges I want to do it with a V-shape conical tool.
    I want to make it in 4 axis so the tool has to stay normal to that surface. It's not a problem that the tool will leave an angle.
    I have tried with project line and with contour offset, but the step downs are normal with each other in vertical and I don't get the sharp corner achieved, but I'd get it with radius.
    To do that the first steps has to be in the edge going in a draft line, till it touch the bottom.
    Is this any strategy how to do it? (Not in 5 axis).
    Please see the pictures for better understanding.
    Thank you,
    Ronald
    Jun 2014
    20
    Re: 4 axis toolpath strategy needed to do the edges with a V-shape tool
    Are you able to do swarf milling strategy?
    Sent from my SM-A405FN using Tapatalk
    Everyday is a school day.
    Jun 2014
    20
    Is the head of your machine able to tilt the a and c axis?
    Could you not just create a comp curve pattern then pattern machining. Would take some editing so you only cut the edges you require etc. But that could work well.
  1. Toolpath strategy
    By dedelecowboy in forum Alphacam
    Last Post: 11-16-2020, 07:01 AM
  2. 3D toolpath rolls the edges
    By dkrenfrow in forum Mastercam
    Last Post: 04-04-2018, 02:40 PM
  3. 3D toolpath strategy ( approach) advice !!
    By Robert M in forum Mastercam
    Last Post: 04-04-2016, 06:15 AM
  4. Grooving toolpath strategy advice
    Last Post: 02-17-2015, 01:40 PM
  5. 3D toolpath strategy advice !!
    Last Post: 11-20-2013, 12:22 PM
