586,011 active members*
4,809 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > To Okuma Corporation
Results 1 to 10 of 10
    Oct 2009
    114
    Hello
    The pulse handle system in double columns is not. useful. Cable is short and pendant arm very heavy. A remote control pulse handle with a 5 inch
    screen would be better. Of course CE regulations will change. Regulations also should be changed. It is not a boarder.
    Jun 2015
    4154
    Re: To Okuma Corporation
    hy is it worth it, if you replace it with a longer cable ? what table size is your mcr ?
    on your phone, you could use an app that shows osp screen; some persons use a tablet ( because it has a bigger scrren ), that is conected via teamviewer
    you could also consider a case for it, so to protect it from chips
    if you wish to go remote, then you can configure an app on the osp, that takes input from tablet, via teamviewer, and passes it to the controller; api, or without it
    if you wish, i can help you / kindly
    Mar 2009
    1982
    Thank you for valuable input, Mr. MCR-B II. I guess, you are new to this field.
    Okuma will drop the design philosophy and follow your advice instantly. The old machines will be retrofited. Is that OK with you?
    Oct 2009
    114
    Quote Originally Posted by deadlykitten View Post
    Thank you for your reply.
    Table sizes from 3 meter to 8 meter.. But who prepares remote api app.. Is there an app. for okuma.
    kindly
    Jun 2015
    4154
    no, there is no app for that, but i can try to help you is your osp windows based ? do you have io monitor ?
    Oct 2009
    114
    Yes Windows 10 io monitor yes
    Jun 2015
    4154
    okey please check your private message
    Aug 2007
    81
    If you have a schema or the ability to probe the signals from your remote dongle. A spliced in remote device could be made that directly manipulates the signals in parallell with the current pulse remote.
    This can be made with a cheap Arm M0 and a small Point to point sender / receiver of "some sort".. bluetooth or radio or IR..
    PM me if you wanna discuss this route - i can make it prob. but will need some more info.
    Oct 2009
    114
    Again To Okuma corporation
    This two pdf pages : Oil recomendation : Which is correct Attachment 485330Attachment 485330
    Jun 2015
    4154
    those are different, because only 2nd is heavy-duty
  1. From Syil Machine Corporation !
    By syil in forum Syil Products
    Last Post: 03-18-2018, 07:41 PM
  2. Ebtec Corporation
    By bamalam12 in forum News Announcements
    Last Post: 07-18-2011, 05:59 PM
  3. Corporation Thanking Letter
    By HAO MAU in forum News Announcements
    Last Post: 03-10-2010, 02:15 PM
