585,605 active members*
3,387 visitors online*
    Jan 2019
    Inlay tearout
    Help! I built a machine after watching YouTube videos and reading online. I got it to run a program, and tried to carve an inlay. I am using a brand new 30 degree 1/4 inch bit, on a spindle running at 12000RPM at 60IPM feed rate. I'm carving in half inch mahogany. I've tried several times to carve the wood, and it always rips the wood to bits. What am I doing wrong?
    I've posted the image from Aspire, and the actual carving.
    Nov 2014
    724
    Re: Inlay tearout
    No image but run the program again and that will probably clean it up. You can drop Z by 0.001" for the second pass if you like.
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    1213
    Re: Inlay tearout
    Are you conventional cutting or climb cutting?It might help to try the alternative if the grain is causing the tearing.I don't think 0.001" will do much cleaning if the tearing is already present-I use 0.3mm as a typical cleanup pass.
