586,005 active members*
5,181 visitors online*
IndustryArena Forum > Manufacturing Processes > Turning > Can't Reference EMCO 360 Turn
    Jun 2021
    I re-commissioned my EMCO 360 Turn because of a battery failure. Machine was running fine before the memory was lost, after re-commissioning when trying to REFPOINT by pressing X+ the axis does not move unless the Aux On is held at the same time, then the axis will move to the reference point. This is the same with the Z+ axis. I have seen in other posts that guys were having problems with the PCP not fully loading. I think my PCP is fully loading, but I'm not sure how to tell. Any help would be greatly appreciated.
    Jun 2021
    Re: Can't Reference EMCO 360 Turn
    Update, I got the machine to Reference +X and +Z normally and everything works as it is suppose to except the Hydraulic Chuck. I can change the 5008 Bit to inside or outside and it doesn't have any effect, so I think I'm still missing something that controls the hydraulic chuck. Any help would be appreciated.
