585,942 active members*
3,376 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > milling supper thin material.
Page 1 of 2 12
Results 1 to 20 of 32
    Apr 2018
    19
    Lightbulb milling supper thin material.
    I'm newbie. my Customer send me a mill job with the thickness of part is 0.004". instead giving me stock size 0.004" they send me material with thickness is 0.025" and ask me to face it mill to 0.004".
    I have no Idea how to machine this. any suggestions will help. thanks a lot
    Dec 2013
    5717
    Re: milling supper thin material.
    What material? What size?
    Depending on the material you may be able to glue it down to a flat surface and mill it, but the final thickness of 0.004'' is really thin and this won't be easy.
    It might be better to try to find the material in the proper thickness.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2015
    178
    No quote.
    15362
    Quote Originally Posted by longnho View Post
    What is the material they want machined, and how big are the parts
    Mactec54
    Apr 2018
    19
    material is Aluminum 6061 - size 2.00"x3.00"x0.024"
    - - - Updated - - -
    the part is 2*3 (inchese)
    Dec 2013
    5717
    Here is a 6''x50'' roll of 0.004'' aluminum shim stock https://www.mcmaster.com/9708K54/
    Jim Dawson
    Sandy, Oregon, USA
    15362
    - - - Updated - - -
    This company has the 6061 .004" shim stock https://www.spirolshims.com/aluminum.html
    Mactec54
    Apr 2018
    19
    thanks all.
    Jun 2010
    4256
    Your customer is an idiot.
    Buy some 4 thou shim stock from ebay and make the parts out of that.
    You may find it necessary to sandwich the 4 thou stuff between 2 or 3 mm Al plate if you want neat results, otherwise the edges will be badly torn.
    Failing that, laser cut or waterjet.
    Cheers
    Roger
    Apr 2018
    19
    Quote Originally Posted by RCaffin View Post
    Cheers
    Roger
    I have no idea. they said material is Aluminum and sent me SS plate. I called back to confirm and they said part makes by SS.
    sandwich part with aluminum is a good option.
    thank you for suggestion.
    Mar 2008
    683
    Cheers
    Roger
    The customer is always right . If they want .024 faced down, charge accordingly. Let a 100 job become a 1000 job.
    However I think they will reconsider when presented with the option.
    Apr 2018
    19
    Quote Originally Posted by warrenb View Post
    you are right. customer never wrong. ))
    Mar 2008
    683
    Holding down would be fun. How would I do that.....
    I would probably put a bit of lacquer or water based glue on a flat piece of spoil and press it down like one is gilding something, cut it, the soak it in a solvent to dissolve the glue.
    Apr 2018
    19
    I'm thinking about using glue and hold it down the table with support from some screws. then use 1/8 endmill to slowly face it down to 0.004". ( bigger endmill will break the part)
    hope it works.
    Jun 2010
    4256
    Oh, not wrong - just a complete idiot.
    I would like to see the results of gluing the stuff down and facing it. My best guess is a shredded mess.
    I do machine shim down to about that thinness - but ONLY ever sandwiched.
    Cheers
    Roger
    Mar 2015
    178
    This keeps getting and better better
    You realize SS will be an absolute bear especially if it’s 3xx series. The whole thing about milling down .024 to .004 is whacked.
    You are in for bad times. Buy a roll of .004 SS shim stock as suggested, pay someone to laser cut to shape and pass the cost on. Your customer is an idiot or a 20 something newb engineer (cartoonist) don’t follow them down a rat hole.
    Mar 2017
    926
    I made some aluminum shims for myself recently. I'd suggest bolting the thin aluminum you plan to face to a thicker (and already flat) piece of aluminum.
    Aluminum that thin will just bend out of shape if you try to hold it in a clamp or vacuum table.
    You'll have to use coolant and avoid high rpm to avoid melting it.
    Jun 2015
    4154
    nice idea
    Apr 2018
    19
    Quote Originally Posted by Goemon View Post
    Apr 2018
    19
    Quote Originally Posted by Paul-JB View Post
    I told them about that but they still asked me use material they supplied. so face it to the thickness of the part is only one choice
Page 1 of 2 12
  1. thin plastic material for engraving
    By monkeyfist in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-16-2015, 09:39 PM
  2. Thin plastic engraving material
    By brian257 in forum Engraving Machines
    Last Post: 03-01-2013, 10:14 AM
  3. Best way to hold thin material for milling
    By toothandnail in forum MetalWork Discussion
    Last Post: 10-01-2012, 10:34 PM
  4. holding thin material on lathe
    By 40fordcoupe in forum MetalWork Discussion
    Last Post: 08-24-2011, 04:08 AM
  5. Any way to limit warping on thin material ???
    By flyinwilly in forum Waterjet General Topics
    Last Post: 03-11-2011, 05:02 PM
