585,991 active members*
6,624 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Seeking advice: 2x4' router with ATC spindle for $10-15k
    Question Seeking advice: 2x4' router with ATC spindle for $10-15k
    Hi all,
    I apologise if this topic has been covered numerous times; I searched and scrolled but only found threads that were many years old.
    I'm wanting to buy a CNC router to process hardwood and some light aluminium, with a 2' x 4' working area and an ATC spindle (preferably air-cooled). My budget is ~$15k and it would ideally be turnkey (or close to). I've been looking into the Stepcraft Q.204, but am a little concerned by the round rails on the Y-axis (instead of linear guides) and the lead screw on the Z-axis (instead of a ball screw).
    Other makes that offer products in this segment that I've looked at (Axiom, Shopbot, Camaster). It looks like the Laguna iQ Pro does come with a 2x4' table option that puts it just outside this budget (~$16k). For $15k I should be able to piece together a solution with AvidCNC, but I'd rather get a turnkey solution (and it looks like the Avid uses rack and pinion rather than ball screws for X/Y-axes).
    I'd love any other suggestions to look into and/or experiences with the Stepcraft Q that might allay my fears.
    Thanks in advance!
    EDIT: I should add that I'm planning on working on smaller, detailed parts so repeatability and precision is very important to me.
    Re: Seeking advice: 2x4' router with ATC spindle for $10-15k
    Quote Originally Posted by AdventureTim View Post
    Hi all,
    Thanks in advance!
    The Laguna is by far the best option. The stepcraft has some bizarre features like a long belt drive system and the bearings you mentioned. Shopbot is good but expensive for the size you're looking for. Camaster is OKAY, but does not have the nice bearing system and screw drive on all axis like the Laguna. ATC isn't even an option, and it's gantry is limited to 9" as an upgrade. Dollar for dollar, Laguna is a better value than all of the other options.
  1. Seeking Spindle Relay Advice
    By Malachite in forum DIY CNC Router Table Machines
    Last Post: 08-15-2021, 02:58 AM
  2. SEEKING advice on buying a ATC on ebay
    By routermaker in forum Chinese Machines
    Last Post: 09-22-2020, 02:57 AM
  3. Seeking advice for DIY router design
    By mogu in forum DIY CNC Router Table Machines
    Last Post: 07-16-2014, 04:45 AM
  4. Seeking advice on engraver/router
    By Danskur in forum Commercial CNC Wood Routers
    Last Post: 06-07-2010, 07:51 PM
  5. seeking advice on spindle lift
    By ponch37300 in forum DIY CNC Router Table Machines
    Last Post: 12-23-2009, 01:21 AM
