585,698 active members*
3,424 visitors online*
    Post Mach3 THC301d input and output pin numbers
    I running Mach3 with a Texas Microcircuit THC301d with a parallel cable to com port 2. Everything was working fine till my break out broad for the servos went dead. Got a new break out broad installed and got it up and running but my THC doesn't work. I think I changed a few pin numbers. I should have recorded everything. Does any one have an installation manual or the the pin numbers for the inputs and outputs used by the THC301d.
    Inputs port 2
    E-Stop
    THC on
    THC up
    THC down
    Outputs port 2
    I do not know what's needed for outputs.
    Re: Mach3 THC301d input and output pin numbers
    It all depends on what Break-out-board or motion controller you're using. I have the machmotion setup which comes with mach3, the apollo1 controller, or break out board, and the thc 301d. If you're using apollo1 or IO6, I have manuals for them. Also, what machine torch are you using?
  1. Mach3 output pin only gives 0.6v
    By japes in forum Controller & Computer Solutions
    Last Post: 07-12-2018, 09:39 AM
  2. Mach3 write input numbers-what are they
    By pasofinojls in forum Engraving Machines
    Last Post: 07-13-2014, 04:47 PM
  3. Can I swap an output pin to an input?
    By GTFreeFlyer in forum Mach Mill
    Last Post: 12-22-2013, 05:26 AM
  4. Need motor output pin # for Mach3 plasma cam
    By DavidJB in forum Waterjet General Topics
    Last Post: 04-24-2012, 12:30 AM
  5. Parallel pin 01 - E-stop use as Input or output?
    By mike944 in forum LinuxCNC (formerly EMC2)
    Last Post: 12-03-2007, 03:39 PM
